VAC Hydraulic Lift Creeps Up
M5G
09-28-2005 13:45:15
My VAC hydraulic system (not eagle) creeps up when system is in down position.
Can someone shed some light on what is causing this to occur? Thanks for your help!
Eric Foster
10-04-2005 09:06:59
 Re: VAC Hydraulic Lift Creeps Up in reply to M5G, 09-28-2005 13:45:15
The service manual mentions the following 3 possibilities:
1- Oil too heavy for existing temperature
2- Screws in actuating lever not properly adjusted
3- O-rings in pressure control valve leaking - pressure developed behind plunger
Eric
Jerry W
09-29-2005 05:19:39
If your hydraulic filter is clogged it could create enough back pressure to lift the arms - especially with no load.
Jerry
Gary Cash
09-29-2005 14:23:24
 Re: VAC Hydraulic Lift Creeps Up in reply to Jerry W, 09-29-2005 05:19:39
What kind of controller do you have? If it is a three position lever i.e., up-center-down with a spring return to an open center, you could have a leak in your spool seal between the up and open center allowing hydraulic fluid, under pressure, to slowly raise your 3-point.
Go on-line and search under "open center hydraulic system" and you'll find a nice diagram.
