1950 DC Engine ?'s
John Olson
09-29-2005 13:49:21
I have noticed that on my tractor there are numerous covers on the sides of the engine and transmission or torque tube.Are gaskets readily available for these,or do I make my own? Right now they are sealed with a lot of blue silicone.Not a neat job of doing it either.John.
L.Lamp
09-29-2005 19:40:07
 Re: 1950 DC Engine ?'s in reply to John Olson, 09-29-2005 13:49:21
All DC engines have 4 inspection covers, two on each side of the pan. New gaskets come with a complete overhaul set along with new copper washers for the bolts. The covers on the engine were meant to allow changing a rod or piston from the bottom without taking off the head. The two in the side of the clutch can be bought separately from your Case-IH dealer. They allow access to adjust the clutch.
Camboted
09-29-2005 20:18:11
 Re: 1950 DC Engine ?'s in reply to L.Lamp, 09-29-2005 19:40:07
The inspection covers on the oil pan are no problem, silicon is fine. However the covers on the side of the transmission are another story. They have shims under them that allow you to adjust the end play in the transmission shafts. These need to be adjusted to allow free turning without end play by adding or removing shims. I suggest you buy a manual off of ebay.
John in Ne.
09-30-2005 05:22:09
 Re: 1950 DC Engine ?'s in reply to Camboted, 09-29-2005 20:18:11
Thanks,Now do I go to the New Holland dealer who was once a Case dealer or to the Case/IH dealer who was once the IH dealer?Or the AGCO dealer who sells everything but Green? I'll find 'em,John.
Paul f
09-30-2005 06:04:10
 Re: 1950 DC Engine ?'s in reply to John in Ne., 09-30-2005 05:22:09
I went to Case about a year ago to get the little washer/seals/gasket part #O789AB that go on the engine inspection port bolts ( you need 16 of them) Case wanted $4 each!!!!
jal-SD
09-30-2005 05:50:23
Check with Don Livingston, 18024 540 Ave, Austin, Mn. (507) 433-0073, AM best or e-mail him at: manifold@smig.net - he'll probably have them. (My $0.02 worth. jal-SD)
