1070 hydraulic pump
clarkscreek
10-06-2005 07:20:53
I have a 1973 1070 with a powershift transmission. While on a downhill slope I hit the brakes to stop and had a strong vibration in the brakes as if I was low on hydraulic oil. When I backed up on level ground I lost all hydraulics. Is there a simple way to determine whether it is my hydraulic pump or further internal problems?
bigJ
10-06-2005 18:04:43
 Re: 1070 hydraulic pump in reply to clarkscreek, 10-06-2005 07:20:53
It is very important that you keep the transmission topped up. If it gets low and you go downhill you will loose all hyd. power including brakes and steering. I know this from experience and a broken utility pole and a busted fence. Plus, numerous run aways.
