380L/L Case/David Brown
Terry
10-24-1999 20:37:49
We have rebuilt the tractor and now we are having problems starting it. It will start fine if you use starting fluid, but it will not start on it's own. Could this be a timing problem? If so does anyone know the correct timing setting?
Elmer
10-25-1999 05:00:40
 Re: 380L/L Case/David Brown in reply to Terry, 10-24-1999 20:37:49
Their should be markings on the mounting flanges. And if you timed the gears properly, it should start OK. I had one once where the snap ring on the vertical shaft was not in place and the shaft fell down 1/16", made alot of difference because the gear is helical cut. The bell housing has two holes for spill timing as well. One is TDC and the other is spill. If you need more info email me back.
