1980 case 1150b trans press drop
matthew coyle
10-26-2005 21:25:12
I recently just fully serviced my loader with oil filters etc. when i went to use it the folling day it ran for about a half hour and then i noticed the trans pressure was dropping so i kept going for a lil and i started losing power almost to were it would barely move . the folling day i started it up and the trans pressure was fine and ran for about a half hour and did the same thing started dropping in pressure. Like a dumby i was told it was probably the charge pump and it sounded logical so i did it .. nope i also thought maybee it was the imitation hydraulic oil i grabbed from work .. nope ....if any one could help me out at all that would be great
Roger (Mi)
10-31-2005 03:40:21
 Re: 1150B crawler/loader? in reply to matthew coyle, 10-26-2005 21:25:12
Did it work well before servicing? Is there good pressure when NO clutch packs are engaged (neutral)? Torque converter pressure drop?
