Case 201 gas motor will it swap into a Case 310
Fred Mauro
11-02-2005 03:02:47
I have a case 660 combine with a good 201 gas and a case 310 crawler with a blown engine. Will the 201 fit the bell housing of the 148 gas motor and starter etc work. I heard it was longer but, I can deal with that. If any one knows please advise!! Thanks, Fred
mikes600
11-02-2005 17:37:20
 Re: Case 201 gas motor will it swap into a Case in reply to Fred Mauro, 11-02-2005 03:02:47
I put a 188 gas in my 310, i had to use a 530 torque tube.Everthing was a bolt in after that.The hood was extended 1 "
Eldo case
11-02-2005 06:42:45
No the bell housing is smaller on the 310. But you can redrill the engine to fit. It is a pretty good job to do.
