2390 vs. 2590, what's really the difference?
rwkc79
11-02-2005 14:22:46
My dad has a 2390 he bought new that is pushing 9K hours (engine overhaul at 7500). Since I left, he has added a 2594 to the "fleet". Lately, I"ve been going back and helping more due to his health problems.
As expected, the 2594 is noticably stronger. I have always heard there was very little mechanical difference between 2390/2590 or 2394/2594. Does anyone know what they changed? Bigger Turbocharger? Fuel pump settings? Drivetrain?
Roger (Mi)
11-04-2005 03:18:32
 Re: 2390 vs. 2590, different cyl. heads and pump in reply to rwkc79, 11-02-2005 14:22:46
Oldest son drives a pro-stock CASE tractor in tractor pulls. He's more up on the larger Case tractors and their differences. The 2390 heads use pencil injectors and their fuel injection pumps have a smaller capacity. The 2590 heads use a much larger (physical size) injectors with a pump that really delivers fuel. There are additional drive train differences too.
Can't even use my name
11-04-2005 04:54:17
 Re: 2390 vs. 2590, different cyl. heads and pump in reply to Roger (Mi), 11-04-2005 03:18:32
Our 2390 doesn't have the pencil injectors, they screw in like the 2590 motor we transplanted into one of our 1270's. I think all the 90 series had the screw in type while the 70 series had those impossible to remove pencil injectors.
11-02-2005 18:16:30
 Re: 2390 vs. 2590, what's really the difference? in reply to rwkc79, 11-02-2005 14:22:46
I think the 2590 has a few extra clutchs and reaction plates to handle the extra torque. 2390's were 160 horse and the 2590's were 180 horse with the only difference I know of being the pump setting. I am sure the turbo's and everything else engine wise the same except the max fuel rate.
c hess
11-02-2005 15:23:41
1 difference if my memory is correct 2590 had 4 pinion differential ehile 2390 had 3.
kcrw79
11-03-2005 05:43:14
 Re: 2390 vs. 2590, what's really the difference? in reply to c hess, 11-02-2005 15:23:41
Thanks for the info!
I was always curious since I knew the 23/25's had the same engine, where as the 20/22's ran a smaller crank. In any case (pun intended), not a good idea to just open the fuel pump since the 25 has heavier tranny & rear end components. The 2390 always ran close to 180 HP on the dyno anyway. We've never had the 2594 on the dyno, but suffice to say it handles a 15' disk chisel reasonably well, while the 2390 struggles.
