1070 Case Engine
Shorty
11-04-2005 18:04:40
I have a 1070 engine, serial #A451BR. Will it fit in a 1030 case tractor? My cousin has a 1030 with bad engine. I have a 1070 with good engine, bad transmission. Will the engine from the 1070 fit into the 1030? Thanks
michael
11-12-2005 14:58:39
 Re: 1070 Case Engine in reply to Shorty, 11-04-2005 18:04:40
my father had a 970, 1070, and a 1030 case. they were excellent tractors. the 1030 had a bad engine that was a 1969. i think you could put a 1070 engine in a 1030. goodluck let me know how you make out and how it runs
Jim Handke
11-04-2005 20:12:36
It"ll bolt right up. You"ll have to bore a hole through the left hand flange for the 30 series steering shaft and the injector pumps are on opposite sides, so you"ll get creative with throttle linkage.
Roger (Mi)
11-05-2005 03:50:20
 Re: Don't forget the sheet metal in reply to Jim Handke, 11-04-2005 20:12:36
Jim is right. Just needed to add that 70 series have cross flow heads (intake on one side, exhaust on the other). You'll need to make some sheet metal adjustments because of its configuration and size.
jim handke
11-05-2005 18:25:58
 Re: Don't forget the sheet metal in reply to Roger (Mi), 11-05-2005 03:50:20
I don"t know how that slipped by me. Had a senior moment, I guess.
