1070 manual won't move
nb
11-10-2005 16:52:05
It will not move in any gear. With the clutch out, it will grind for few seconds as you try to put it in gear, then nothing. I"m thinking maybe some pins broke on the clutch, or the input shaft going to the tranny broke. Any thoughts?
Rahlo
11-20-2005 21:23:56
 Re: 1070 manual won't move in reply to nb, 11-10-2005 16:52:05
Sounds like the main shaft is broke. We had a 1175 that did the same thing. This shaft is the same in 930, 1030, 970, 1070, 1090, 1170 & 1175. They are easy to find. Good luck in your repair.
