2290 brakes problem
Rick Schaefer
11-12-2005 07:05:50
Just purchased a 1979 Case 2290 with 4600 hrs. Has not been used in the last three years. RH brakes mushey, will work when pumped. Have not yet bleed the system. The problem, the LH brakes. No give in the brake petal. As if it is bolted to the frame. Any ideas? Really need help on this one. Also, new to Case tractors. Thanks. Rick
WALTER T.
11-12-2005 17:20:44
 Re: 2290 brakes problem in reply to Rick Schaefer, 11-12-2005 07:05:50
THE ORING'S ARE BLEEDING FLUID AROUND THE BRAKE ROD.TAKE THE UNIT OFF REPLACE THE ORING'S AND GASKET.R.H MIGHT BE BLEEDING THROUGH THE SYSTEM'S VALVE SEPERATION BLOCK GASKET.
