1816 Case uniloader skidder
Dave
10-26-1999 22:51:02
Just bought used(older on with toggle switch for hydra) In greatshape and new tires. Motor been bored 20 over ,but has no power to hardly turn around..It has a loud pecking.but not rod, they tell me at Case dealer ..Is it worth motor or junk...Dont burn oil..gets hot and powers out!!and noise gets louder need bigger one!I hate to junk it,,found bigger one(4 cyl New Holland)but hydralic pumps (three in row)need rebuilt ,says $2500.00 but dont know if it cost that much or not.Thanks for feed back dave
Jerrie Lott
10-30-1999 17:44:07
 Re: 1816 Case uniloader skidder in reply to Dave, 10-26-1999 22:51:02
What kind of motor does it have? If it is an Onan, it probably isn't worth fixing, they just don't work good in skid loaders, because of the angles you put the machine in half the time the motor is either starved for oil or it runs to the other end and gets sucked by the pistons. They are probably okay for other applications, but not skid loaders. Anything you fix on a skid loader seems to be expensive, if all three of the valve need rebuilt $2500 probably isn't way out of line.
