2290 Power shift will not come out of HI
Joe Prince
12-06-2005 18:55:03
On my 2290 the Power shift is locked in HI. I replaced the filters and this made no change. If I have to split the tractor do I have to remove the cab? Is replacing the cluch pack a major task?
aney help are coments welcome.
Thanks Joe
c hess
12-07-2005 05:58:02
 Re: 2290 Power shift will not come out of HI in reply to Joe Prince, 12-06-2005 18:55:03
YOU DO NOT NEED TO REMOVE CAB . First you need to check simple things. Can you move shifting leaver same as usual? Does foot clutch seem same as usual? Check to see that valve is moving correctlywhen you move power shift .You may need to have some one with proper gages check before you begin to take apart. Others on forum can help.
c hess
12-07-2005 17:57:05
 Re: 2290 Power shift will not come out of HI in reply to c hess, 12-07-2005 05:58:02
Read your other post an i still stand by my first post. I think you need to make sure valves work an you need nowegable advice on problem before you tear down an spend money you mentioned. Call me an i will direct you to case folks who can give advice, There are others on forum who can help also. 419-673-9463
