1370 hyd. problem
melvis pigsley
12-11-2005 18:33:32
My 1370 is having problems with the steering and power shift, works ok when fluid is at op. temp. Full of fluid. As the the small part of the pump is for brakes and stering and the big part is for hyd. and powershift I assume I have a supply problem, either charge pump or filters, which were changed 2 years ago, I don't put alot of hours on it per year. If the filters were plugged and the bypass opened would this supply enough oil? Unfortunately the filter pressure gauge is inoperative. Am I on the right track, any suggestions, any help appreciated.
Don2004
12-12-2005 18:37:58
 Re: 1370 hyd. problem in reply to melvis pigsley, 12-11-2005 18:33:32
You might need to check the suction screen if new filters don't work.
John Saeli
12-12-2005 04:08:35
Hey Melvis: 2 years is long enough. We've had to change them filters twice a year sometimes. How's the Oil quality? Has it picked up moisture? Good Luck
