1030 hydraulic problem, please help!
1030 owner
12-18-2005 17:21:32
I have a 1969 1030. when i pull my box scraper behind the tractor, i can raise it, but as soon as i let off the lever, the scraper starts sinking back down. What is wrong? Any help is greatly appreciated.
1030 Owner
12-19-2005 08:40:40
 Re: 1030 hydraulic problem, please help! in reply to 1030 owner, 12-18-2005 17:21:32
Yes, the cylinder is fine. I have switched the hoses around every which way and it still does it.
Triplerange
12-20-2005 08:23:27
 Re: 1030 hydraulic problem, please help! in reply to 1030 Owner, 12-19-2005 08:40:40
Sounds like the cylinder is leaking internally if you switched the hoses around and had the same problem.
dwag
12-18-2005 17:32:33
1) Hyd cyl OK? 2) Swap hoses to other couplers and try.OK? 3) Swap hoses side by side(control lever will work opposite... push ahead to raise)OK? Could be a problem in thermal relief valves, or large check balls in center of remote valve housing.
