148B block problemes
don oryall
03-26-2006 12:19:20
got a 148B throw a rod out the side of block having a hard time finding a new block does someone know where to find one or what engines will fit in its place it is a cas o matic thanks
CH
03-27-2006 16:40:40
 Re: 148B block problemes in reply to don oryall, 03-26-2006 12:19:20
I just got a 310G crawler in and i believe it should have had a 3 bolt starter but it has a 2 bolt so must have had a engine change. Anyways i havn't started it yet but it's for sale (the engine) If interested i will get it running.
mike's600
03-26-2006 12:47:38
I think i have a short block, it has the three bolt starter flange.
don oryall
03-26-2006 13:23:44
 Re: 148B block problemes in reply to mike's600, 03-26-2006 12:47:38
I thank you this 148B is a 2 bolt starter I have found 159 3 bolt but no 2 bolt thanks mike"s600 don
Mikes600
03-27-2006 04:14:31
 Re: 148B block problemes in reply to don oryall, 03-26-2006 13:23:44
A Vac block will work, you will need to bore it out to get the 148 cu.
