1030 pto locked ?
Mike JP
04-04-2006 12:28:41
Neighbor was cutting hay. first time PTO used in about ten years. Tractor quit and won't turn over. It just seems unlikely the motor went, anyone think the PTO may be problem. The PTO shaft barely turns with tractor in neutral.
Grumpy
04-06-2006 05:10:30
 Re: 1030 pto locked ? in reply to Mike JP, 04-04-2006 12:28:41
Problem with PTO not likely. Will tractor move with trany in neutral. Take starter off and try to turn motor with crowbar. If motor wont turn then you need drop pan look for stuck rod or main bearing. Let us know what you find. Stan
BarryfromIA
04-04-2006 18:18:22
Early 1030's would break a shaft in the pto drive train.This may have been when using the 540 pto set up. Some of these "spare" parts could get between the bull gear and the bottom of the gear case. You can imagine the problems this can cause. Hope someone has a more cheerful answer.
c hess
04-04-2006 13:48:25
Did engine stop sudden?First i believe there is a bolt in end of engine crankshaft that you should be able to put asocket on an engine should turn if ok .Kant imagine anything hapening to pto that would not let engine turn .Check engine first. Does oil smell burned?Try to find trouble before you try to start tractor.Grumpy OR Rodger or Others might have answer.
c hess
04-04-2006 13:48:02
