1370 Fuel tank repair
nna
04-21-2006 18:56:16
I'm looking for advice on how to repair a small hole in a 1370 fuel tank.
shawnspeed2
04-23-2006 17:22:35
 Re: 1370 Fuel tank repair in reply to nna, 04-21-2006 18:56:16
What caused the hole ? rust or ware? I have patched holes in many a fuel tank,if it is rust ,look for another tank, if it a worn spot or puncture, you can have the tank PROFFESIONALLY welded/soldered shut,and metal finished to like new. J/B weld will hold for a while, but gas and diesel will eventually loosen its hold. Good luck Shawn
nna
04-23-2006 21:00:54
 Re: 1370 Fuel tank repair in reply to shawnspeed2, 04-23-2006 17:22:35
Thanks for the replies. The fuel tank on a 1370 is not metal but some kind of plastic. It has a slot in it (don't ask how, I'll just say it wasn't a good day). I think I have it fixed, time will tell if it was successful.
CK from ON, Canada
04-21-2006 19:29:36
Ive had good results on a 440 tank. I cleaned the tank well and filled hole with JB weld. I have also heard of people drilling hole out to be round, tapping it, and installing a machine screw with pipe dope or teflon tape on it.
