Case 900 PTO option
JR Long
11-08-1999 06:28:37
I just purchased a 1959 Case 900 with a Meade cab. The cab floor covers the area where the PTO shaft would come out if it had that option. I would like to add the PTO option to the tractor (even if I have to remove the cab). My question is this. What part are required to add the PTO?
Thanks for any insight.
900CaseGuy
11-10-1999 11:33:31
 Re: Case 900 PTO option in reply to JR Long, 11-08-1999 06:28:37
I believe there is a lot of stuff involved in installing the PTO on that tractor. It would help if you could find one from a 930 which as I remember is a little better design.
Good Luck.
P.S. Remember, you should always be carefully taking advice from anyone that owns a John Deere.
JR Long
11-10-1999 13:35:36
 Re: Re: Case 900 PTO option in reply to 900CaseGuy, 11-10-1999 11:33:31
900CaseGuy,
I think I can get a complete 930 rear end with the housing, hyd. pump, axles, and PTO. Is it interchangable?
Thanks,
JR
900CaseGuy
11-10-1999 14:11:16
 Re: Re: Re: Case 900 PTO option in reply to JR Long, 11-10-1999 13:35:36
I believe that it should be. Have you had your 900 for long? I was trying to buy one in Colorado last week that seemed like a good deal but it was already sold before I could see it. It must have been a great deal. They're fine machines.
JR Long
11-11-1999 08:54:23
 Re: Re: Re: Re: Case 900 PTO option in reply to 900CaseGuy, 11-10-1999 14:11:16
900CaseGuy,
I just bought mine about a week ago. It is probably the one you were interested in.
I hope the 930 rear end works out as I would like to add the PTO.
JR
