Need 630 Eagle Hitch Lift Cylinder Part Numbers
KCTractors
04-22-2006 10:35:58
I need the rings and rubber seal for the lift cylinder. The piston is a 3 3/4" with 3 grooves. There is a metal ring for the first groove and then a rubber ring for the second ( about 1/8" thick ) and then another metal ring on the third groove. The local dealer gave Part # G4803 for the 2 metal rings, which I believe is right. He gave me a O-ring part# 913107 ( 3 3/8" ) in diameter. When I install the o-ring, it's so stretched, that it does not even fill the groove, so that can't be right. I have the metal rings, but I need the rubber one.Can anybody help me out with the right parts or numbers1
