2390 stuck in Park
clupk
04-25-2006 17:30:54
Is there any remedy for this problem? On any small incline, we end up pulling or pushing the tractor to get it out of Park. Thanks.
c hess
04-26-2006 16:25:45
 Re: 2390 stuck in Park in reply to clupk, 04-25-2006 17:30:54
Ifgoing up hill just turn steering to maximan angle an let it drift back till it stops than use park.Or use Turbos idea -just be gentle an dont snap gear. Engineers must never have parked on hill when they designed it.
turbo
04-25-2006 18:29:22
In our steep terrain, we cut off a 8 inch length of 1/4 X 1 flat iron and kept it in the cab. With the tractor in park, you can put the transmission in gear using this strap in the quadrant, usually second, and you can gently move forward or backwards to release the pressure on park.
