1070 inching clutch
books
05-03-2006 08:47:55
On my 1070 inching clutch i have to let out at top of travel to move .I have to use a board to put my foot on.It shift fine. thanks for info.
oldrusty
05-03-2006 19:48:01
 Re: 1070 inching clutch in reply to books, 05-03-2006 08:47:55
Best guess is that the inching valve spring is getting weak. This spring and torpedo is located in the control valve at the back end of the inching spool. Remove the plug on the control valve and you can remove spring and see if it is broken or colapsed
