Last DC Case Made SN? All 80 DC SN's ?
10above
05-21-2006 08:46:21
There serial number on my case DC is 8026884. How many DC"s were made with the 80 Serial number, and what was the last one? (from what number to what number)...
Walt Davies
05-21-2006 09:11:52
 Re: Last DC Case Made SN? All 80 DC SN's ? in reply to 10above, 05-21-2006 08:46:21
1953 5622406 5622744 339
8022746 8032411 9,666
Total 10,005
(Model mix information: DC3 - 3,622; D - 420;
DC4 - 1,700; DE - 1,830; SI - 125; SC3 - 1,910;
SE - 61; 500 - 335; LAE - 2.) From this time for-
ward, individual tractor model lines were no
longer given their own block of serial num-
bers, but rather all units built at the same
plant shared the same serial number block.
Walt
dctom
05-21-2006 15:45:00
 Re: Last DC Case Made SN? All 80 DC SN's ? in reply to Walt Davies, 05-21-2006 09:11:52
walt: case never did give a block of numbers to any single model, they always did run consetively (sp) for all models built at racine tom
10above
05-21-2006 09:32:39
If I understand correctly, you are saying that 3622 DC3's like mine were built with the 80 serial number, correct, or after 5703622 they went to an 80? I am not sure I understand your term "model mix information". If it is not possible to find out how many DC3's were made, or where in the sequence of DC's mine lies, it would be interesting just to learn information from DCTom about when it was made and any other info - if it has a card. Mine has a narrow front, foot clutch, foot throttle, eagle hitch, and it is regular gas.
I am missing some parts...any good resources?
top link
flywheel
fenders
rubber tortion for rubber on seat
Lights - but I have brackets and it is wired
Otherwise it is complete with great tires - all fluids have been changed, and we have no leaks! We may look at blasting/painting later. It just got home, so we need to do some mowing and blading first.
Walt Davies
05-21-2006 10:07:09
 Re: Last DC Case Made SN? All 80 DC SN's ? in reply to 10above, 05-21-2006 09:32:39
I got this information direct from my book "Full Steam Ahead" by Erb ans Brunbaugh. where they got the info from I don't know but it looks like they got it staight from the JI Case company books. Walt
dctom
05-21-2006 08:52:46
10above; i will look up your tractor but to find out what you want would be a monuntal task, as tractors were numbered in sequence with SC's and DC's and LA's and 500's would have to look at each one and that is over 2000 cards tom
10above
05-21-2006 09:11:04
 Re: Last DC Case Made SN? All 80 DC SN's ? in reply to dctom, 05-21-2006 08:52:46
Thanks Tom - I appreciate any help you can offer. We're looking forward to getting started!
dctom
05-21-2006 15:42:15
 Re: Last DC Case Made SN? All 80 DC SN's ? in reply to 10above, 05-21-2006 09:11:04
8026884DC-3 was built feb 25 1953 and shipped to j i case co luvern minn. june 17 1953 I did try to find the last one built but dont have time to look thru all thoes cards tom
