1988 case 585 hydraulic problems
Pats
05-27-2006 07:47:39
I have a problem with my hydraulics the loader will raise but it is very slow the 3 pt won't raise and the remote in the back of the tractor will not raise the cylinders Any suggestions
weasle
05-29-2006 20:19:35
 Re: 1988 case 585 hydraulic problems in reply to Pats, 05-27-2006 07:47:39
First off, I'd start by changing the filter and maybe a new batch of hydraulic oil... If that doesn't work, start looking at the pump. Had the same problem myself recently with my David Brown and it turned out to be just a blown "O" ring in the pressure side of the pump!!!! Only a 5 cent fix, but I damn near pulled my hair out trying to figure out what was wrong with it!!!
Pats
05-30-2006 06:06:49
 Re: 1988 case 585 hydraulic problems in reply to weasle, 05-29-2006 20:19:35
Hey thanks for the reply I have been rackin my brain oon this I am going to change the fluid and filter if that doesn"t work I will look into the pump.
