2290
wide axle
06-11-2006 05:45:38
Have a 2290, no hydraulics; no pressure on remotes and no lift on 3 point. Oil is full. Any ideas? I think I have lost the pump. Steering, brakes and drive are all fine. It is an 8 speed. Thanks.
case trader
06-11-2006 16:10:01
 Re: 2290 in reply to wide axle, 06-11-2006 05:45:38
i've had most of my trouble with the compensater valve itself stick a guage in your remotes at least 4000# run tractor at fast idle work remote lever if it picks up preas. after 3-5 minutes i change the valve just as well take the wheel off sure is a lot simpler do the easy stuff first (filters)steering works off a seperate pump.should get around 2000# at remotes pump is last resort check bottom of trans. when changing filters if there is a problem you will see something.
dwag
06-11-2006 10:24:35
Servo piston in main hyd pump could be stuck. Compensator will have to be removed to check\free up.
