1941 CASE VC PARTS
TOM GILLETTE
11-12-1999 15:19:56
I AM LOOKIN FOR THE AIR BREATHER TUBE FOR 1941 CASE VC ANYONE KNOW WHER TO FIND ONE???
mike
11-14-1999 19:45:13
 Re: 1941 CASE VC PARTS in reply to TOM GILLETTE, 11-12-1999 15:19:56
Now, that is probably not an easy item to find. I've got a Case V (standard tread) and looked for a long time for the same thing. Finally, I made one using sections of rad hose (molded sections) that I salvaged from a local auto wrecker. The smaller foreign cars seem to be the best bet size wise. I could give you a rough idea of the sizes (lengths) of each of the sections if you respond to my email or in the YT forum. There are two long radius bends, with most of it laying flat on a bench, the last bend turns upwards. I was lucky enough to find 2 molded hoses which together made up the unit and it fits perfect. The join between the 2 pieces was done with a short section of one and one-half inch metal conduit (inside the hoses) and a friction fit eliminated any clamps at the joint. Hope this helps.
