'54 SC Carburetors
L.Lamp
06-11-2006 21:42:48
Are there any other carb models that fit the '54 SC? I am just finishing up the engine for a '54 and would like to use a carb with the 1 1/8" throttle plate bore. I have a couple of new 1" older carbs but I want it to have full power output when I am done.
C. Amick
06-12-2006 09:35:03
 Re: '54 SC Carburetors in reply to L.Lamp, 06-11-2006 21:42:48
Try going to this carburetor reference:
www.tomco-inc.com/Catalog/agricultural&indust.pdf
They have J.I. Case tractors and the carburetors that will fit them listed plus other info. at the end of the document.
L.Lamp
06-13-2006 20:00:47
 Re: '54 SC Carburetors in reply to C. Amick, 06-12-2006 09:35:03
I tried the web address you gave and nothing came up. Those things are awfully picky and if one little thing is out of place your out of luck. Thanks anyway!!
rgorange
06-14-2006 04:04:39
 Re: '54 SC Carburetors in reply to L.Lamp, 06-13-2006 20:00:47
It didn't work for me either, but here is how you can get there:
Link
click on Online Catalogs
click on Carburetion Catalogs
click on Agricultural & Industrial Kits look under JICase.
You will note that you are exactly where Mr. Amick sent you.... just had to take the long road!
Good Luck, Ron
L.Lamp
06-14-2006 06:59:19
 Re: '54 SC Carburetors in reply to rgorange, 06-14-2006 04:04:39
Thanks Ron, I'll give it a try!
