VAC Pullers
1016
06-14-2006 16:43:56
Wanting to start a new project and was wondering where to start. Would like a little input on what other engine other than the stock set up you can go with. Wanting to build something to pound on the local JD Bs
Hank (MO)
06-15-2006 04:14:50
 Re: VAC Pullers in reply to 1016, 06-14-2006 16:43:56
148 engine from a Case 300. Otherwise bore it and stroke it. I've heard close to 200 doing this.
Not to rain on your parade, but not exactly the best choice for a puller in the 3000 group. Small diameter tires (28) = poor ground grip, you can change to larger but then lose the torque. Limited strength bull gears = can't take a whole bunch.
I suspect with the right amount of cutting and removing and $'s you can get a 2500 lb puller that will run well, but not many compete below 3000 in my area.
There are others on this board with WAY more experience than me. If you want to "pound on a Deere" get yourself a WD45.
CLIFF S
06-15-2006 19:11:35
 Re: VAC Pullers in reply to Hank (MO), 06-15-2006 04:14:50
I seen a VAC in Akron Ohio NATPA pull with 13.6x28 on it beat a Super C with 13.6x38 that was powered by a C-153!!! I Also know of a 201 powered VA with a few cubes that pulls at 10 MPH in the 3750lb class in 2nd gear! So Never Count them out!!!
dctom
06-14-2006 17:04:09
201 from a 660 combine
mj
06-16-2006 09:46:04
 Re: VAC Pullers in reply to dctom, 06-14-2006 17:04:09
dctom- How much does your VAC puller with the 201 weigh again? How much does she pull on the sled? Thanks!
