David Brown 990 PTO clutch problem
Marcin
06-25-2006 05:35:50
I have bought DB 990 from 1971 and there is a PTO clutch problem! The clutch for the traction (shifting gears) is OK, but when I want to engage the PTO with attached machine than I just can not do that. It seems that the clutch is not engaging. But I can stop the engine and shift the PTO into working position with my mower or other machine and start the engine and the PTO is workong (0% sliping), but I can not engage it with the pedal!! I have unscrewed the bolt on pedal mechanism to maximum and it still does not work. What is the problem? Do I have to split the tractor?
meadova
06-25-2006 07:40:37
 Re: David Brown 990 PTO clutch problem in reply to Marcin, 06-25-2006 05:35:50
Do you have a serivce manual. You will probably need one. I think you need to make an adjustment to the three adjustments on the clutch. About sure you don't have to split to make the adjsutment but if this don't fix it you will have to put in a new disk. I have a 990 manual or two if you need info e-mail me at cat4.25096@yahoo.com and I will try to e-mail you a copy of adjustment
