188 Crank Gear Removal
Jon(IN)
06-29-2006 11:32:26
Getting a new crankshaft for my 188 Diesel. I will need to install the gear on it. Can I take the old gear off of my original crank? Will it come off easily or require heat or some other method?
Thanks,
Jon
Tom (Ks)
06-29-2006 19:50:58
 Re: 188 Crank Gear Removal in reply to Jon(IN), 06-29-2006 11:32:26
You will need a gear puller to remove the timing gear. There is a thrust spacer behind the gear and the key that you will need to remove. Try not to use any heat.
