1030 injector pump leakage
1031D
06-29-2006 20:23:26
My 1030 is leaking engine oil out of the throttle arm on the injector pump. Can I fix this without rebuilding the pump?
Eagle Doc
06-30-2006 22:37:24
 Re: 1030 injector pump leakage in reply to 1031D, 06-29-2006 20:23:26
The governor housing can be removed from the pump while it is on the tractor, then the seals (O-rings) can replaced as long as the bushings are not too loose in the gov housing. I use Loctite to fasten the bushings in the housing so they don't turn and wear the O-rings out so soon. I also replace the O-ring on the shut-off arm. It usually takes less than an hour and a few dollars worth of seals and a gasket.
DKase
06-30-2006 20:33:08
The governor housing will have to be replaced, and the governor adjusted. Every time I have had one done they ran much better. Some shops will not do anything other than a complete pump job. Call Jerry at 402-388-4990. Mail the pump to him, and he will fix you up. DK
