Case 450 dozer
marc
08-25-2000 15:20:29
what is the best way to replace the 4 hoses that run through the dozer c frame?is there supposed to be a access cover somewhere?frame was welded in some places.trying to pull new hoses through,with old hoses.alot of dirt in frame.
Wilson
08-30-2000 20:40:56
 Re: case 450 dozer in reply to marc, 08-25-2000 15:20:29
I have a 450B Dozer. I had to replace some steel hoses from in front of the radiator to the rear of the engine. It was not fun. I first had to dig out the grease and dirt. I used rubber hydralic hoses instead of the steel pipe hoses. This made it alot easier to bend them under the radiator and along the frame. My hoses had a junction at the rear of the engine, up against the inside of the frame, then they continued on to the rear of the machine.
