Blade will not shine up
Ron
12-09-2000 15:48:04
I have had this dozer for two years and have never had the blade to shine up yet. I have built a water way, pushed brush, pushed in ponds, built miles of teraces and sitll will not shine. Any one have any good advice?
shannon
12-24-2000 07:29:00
 Re: Blade will not shine up in reply to Ron, 12-09-2000 15:48:04
i had trouble with snow sticking to the blade on my tractor once. i just used a 6" wire wheel on a grinder to remove all of the rust and old paint then spray painted it. works and looks like new.
robert plumadore
12-24-2000 06:56:00
It sounds like your blade had a lot of rust and is pitted. If it is important to get it shinned up my advice is to get a sheet of T1 steel broke to fit and reline the blade.
robert
12-09-2000 18:12:45
Have a harvester front which was the same , last owner never shedded it, took off 1400ac of cereals & lupins & never polished it up ,Yes it fed lousy, had it sandblasted this year & thick coat of red oxide now we are nearly finished its as smooth & shiny as a marble floor.
Something you could try
Gary OC 46
12-10-2000 14:58:48
 Re: Re: Blade will not shine up in reply to robert, 12-09-2000 18:12:45
IF you want that blade to shine grade some small stone around. 3/4" or so is good or better yet peel up a section of old gravel road and reshape it. I operate a JD 570 A road grader by day for a Township with 17 miles of gravel roads and I can tell you I have a shiny blade. This stuff takes the paint off new cutting edges in les than a day. On my own time I play with my Oc46 and other small rubber tire tractors.
Stacy
12-09-2000 20:12:33
Some machines will just not take a shine to it's new owner, just kidding, The paint sounds like a good idea.
robert
12-10-2000 03:16:25
 Re: Re: Re: Blade will not shine up in reply to Stacy, 12-09-2000 20:12:33
After last harvest I would have cheerfully fanned the flames if it had caught a light, this yr it has performed faultlessly as soon as I finish i will undercoat it so it stays shiny
Ron
12-10-2000 08:10:22
 Re: Re: Re: Re: Blade will not shine up in reply to robert, 12-10-2000 03:16:25
Thanks for the help. I was thinking about sand blasting, just have to find some one to do it for me. Have a freind that has a farm dozer and he let it set for about six month and the other day he said he push out two trees and it was polished. I could push two hundred trees and mine will not be polished.
phil
03-01-2002 15:51:58
 Re: Re: Re: Re: Re: Blade will not shine up in reply to Ron, 12-10-2000 08:10:22
sounds to me like you havent really put too many hours on your machine. if you use it enough the blade will pollish itself Ps i have operated hvy equipment since i was eight years old and even if your blade is pollished like a new penny
depending on moisture content ground will still stick to them its just there nature
phil
03-01-2002 15:51:20
