Can someone tell me what model this is?
Levi
01-15-2001 14:56:32
third party image
I am looking at one that looks just like this one.
(this pic came from pic gallery here on this site.)
I am looking for any info.
Thanks,
Levi
Barry
08-29-2001 10:16:08
 Re: Can someone tell me what model this is? in reply to Levi, 01-15-2001 14:56:32
It looks like a Terra-trac crawler. The reason it looks like Case is because Case bought Terra-Trac for a crawler division. The ones I've seen pictures of are smaller, but there were several models produced in ther 1950's. I got my info from local bookstores,especially reprints of books by H.C. WENDEL. Hope this helps.
Canadian Cowboy
01-18-2001 21:01:45
Im no expert by any means but im guessing it would be something like a case model 310 cat??
call it a lucky guess if im correct, but close.
Levi
01-19-2001 02:57:56
 Re: Re: Can someone tell me what model this is? in reply to Canadian Cowboy, 01-18-2001 21:01:45
The tag has no model # there is a serial # (which like a dummy I did NOT write down). It is a old Terratrac loader with a 4 cyl. diesel engine, 5 track rollers, and what looks like a mount for a backhoe or a 3 point hitch on the back. At the back it has two big pointed pins on the rear plate, and a hyd. cyl. on each side that pivots in the center of the cyl.(backhoe swing cyl.?) Can't find model #. Anyone know where to look? It has not been started in 7 years but the engine is free so I'm keeping my fingers crossed. If anyone has any info on these little beasts it would be welcomed..
Jack
02-02-2001 20:57:52
 Re: Re: Re: Can someone tell me what model this is? in reply to Levi, 01-19-2001 02:57:56
Are the idlers and sprockets spoked? Is it a three speed with the trans and differential in one case? Mine has 33 pads to a side and the pads are 12" wide. I've got a Case 310G and it looks similar except for the solid piece down the center of the radiator shield and the upper linkage running to the bucket. The one in your picture may be a later model than mine. I'd like to find another 310G. I've about got mine rebuilt but am always needing parts.
mike
01-15-2001 17:23:39
These old terratrac/case tractors are hard to pinpoint with pics only. they were modeled by; size, hp, gas, diesel,number of track rollers, width of track,4/6 cylinder engines. ck with ben, this guy he knows some things about terratracs,
swartb@msoe.edu
james
08-21-2001 04:20:43
 Re: Re: Can someone tell me what model this is? in reply to mike, 01-15-2001 17:23:39
i have one just like it its a terra trac model g556 serial o58 mine has a 4 cylinder gas engine it runs perfect it also has the backhoe attachment like yours but i don/t have it
