Case 450 crawler loader
Brian
02-09-2002 14:57:46
I have resently acquire a Case 450 Crawler that has not been cranked for 10 years. How should I go about trying to get it running again.
jakebrake
02-09-2002 18:06:38
 Re: Case 450 crawler loader in reply to Brian, 02-09-2002 14:57:46
Brian,
Here is a list of what I do. It may not be right but it works for me.
1 drain all fuel and blow out lines to fuel filters and replace filters. Bleed air from lines and filters.
2 Check oil. If on the full mark and only looks dirty then loosen drain plug and make sure no water is present. Do the same with all other fluids.
3 If gas pull the coil wire out, diesel leave stop button out and crank engine for about 30 seconds to get oil moving. then insert coil wire or push in stop button and try it. If doesn't start, start trouble shooting. If it starts let warm up and move it around a little bit and change all fluids and grease all fittings and go dig or push dirt. Lotsa luck
Jakebake
