JD BACKHOE
ALLEN
03-08-2002 18:19:53
OK MEN I NEED YOUR OPINIONS. I AM LOOKING AT A JD 310 C TURBO BACKHOE ID #TO310CB724479 WHAT YEAR IS IT? MACHINE LOOKS STRAIGHT AND CLEAN DIDN'T SEE ANY WELDS. BUT THE ENGINE BLOCK IS GREEN CAME OUT OF A AG. TRACTOR I GUESS.HAS A REBUILT INJ. PUMP. DO NOT KNOW HOURS.WANTS 15,000 FOR IT.IS THIS A GOOD MACHINE OR IS IT PRONE TO PROBLEMS? THANKS
digger
03-11-2002 09:12:59
 Re: JD BACKHOE in reply to ALLEN, 03-08-2002 18:19:53
keep looking you can pickup a 310d with about 3000 hours in it or less with extendahoe less cab for about 20k and yes most likely it will have 4wd, john deere makes the best backhoe hands down imo so if this is the best price you can find tehn you should grab iti would look around though try machinerytrader.com and look for a 310 machine good luck- digger
JONATHAN
03-09-2002 03:37:38
They aren't bad machines...check the reverser to make sure it doesnt slip...smell the oil in it to make sure its not burnt smelling...Not sure what the market prices are in your area but if its 4 wheel drive its not a totally ridiculous price...If its 2 wheel drive I would persuade the seller to lower the price a bit !!
