671 GM oil pressure problem
Matt
05-22-2002 04:14:57
Have a 671 GM which starts losing oil pressure when the oil gets below the full mark.It normally sits about 40 psi at operating revs, but as soon as the oil drops below full, but still well within the operating range, the oil pressure needle starts moving back and forwards. It's an old high block 2 valve motor with only by-pass filters. Any help would be greatly appreciated.
Thanks Matt
Roy Lee Davies
05-22-2002 06:47:34
 Re: 671 GM oil pressure problem in reply to Matt, 05-22-2002 04:14:57
I have never been in a 671, but I had another engine that acted the same way. When I pulled the oil pan off I found that the pickup tube had came off and was laying in the bottom of the pan.
Hope this helps.
