Oliver OC4, OC46 DOZER INFO
Adam
06-09-2002 23:31:27
Anyone know anything about an Oliver OC4, OC46 gas powerd dozer? How many years did they make these. How much horsepower do they make, what are the major problems, and or the wear items on these dozers.
Adam.
glenn
06-12-2002 12:49:04
 Re: Oliver OC4, OC46 DOZER INFO in reply to Adam, 06-09-2002 23:31:27
Weak points on the oc-46 is the transmition.
It seems that the pivot point for the steering
brake/band, cracks inside the trans and by the time you notice it its to late to save the trans
housing.Ive got three oc-46 bad transmition housings. Just my two cents
Crawler boy
06-10-2002 09:43:10
Mod OC-4 where made -56-58
OC 4-3cyl Diesel between -57-65
OC 4-3cyl Gas between -58-65
polk crawler
06-11-2002 06:41:10
 Re: Re: Oliver OC4, OC46 DOZER INFO in reply to Crawler boy, 06-10-2002 09:43:10
Crawler Boy: where on an OC-46-3 will the ID tag be found?. So much loader hardware on this one I have no idea where to look. Thanks. PC
Guido
06-19-2002 18:46:58
 Re: Re: Re: Oliver OC4, OC46 DOZER INFO in reply to polk crawler, 06-11-2002 06:41:10
The serial # is on a plate shaped like the Oliver shield on the left side of the tractor, just in front of the dash.
Crawler boy
06-11-2002 11:23:05
im not sure try to ask on www.cletrac.org disscussionforum i have been helped many times
by helpful people.
polk
06-10-2002 06:38:41
Adam: Get onthe Cletrac.org website; check the brochure illustrations; one is of the OC4 and OC46. The spec sheet has all the info on both the gas and diesel models.
Have my eye on an OC-46-3, Series B. Owner wants to sell, wants too much. Only defect I see is LH front idler outer rim edge and hub is rubbing on frame...outer bushing or bearings could be shot; runs good otherwise. The Cletrac website will tell you a lot you want to know.Good luck. PC
