CASE 310G CRAWLER
Track adjustor and winch question
tim wells
07-08-2002 20:10:02
I have an early G310G Case crawler - the track adjustor have been welded and can't be turned. I notice the late model 310G and 350's had track adjustors that are hydraulic ie use grease. Would the hydraulic adjustor fit the early 310G. Also, I have a C-12 winch not the C-9. It spools in ok but won't lock in place when you want to tow somethng you have to stop and winch the load in?
Any comments or help would be appreciated. Also, the source for for tracks would be nice.
DaleIN
07-09-2002 08:38:52
 Re: CASE 310G CRAWLER - Track adjustor and winch question in reply to tim wells, 07-08-2002 20:10:02
Tim, I sell those hyd adjusters. But, if you have the old spoke type idlers with the big yokes, I don't believe you have the room to put the hyd adjusters in. However, if you're putting new tracks on and use 350 idlers, I think you can update the adjusters. Email your serial number and I'll try to get a more definite answer.
