Case 310 crawler won't crawl!
dell
07-23-2002 14:16:58
Dozer all of a sudden making loud noises almost like cogs slipping, but can't see anything wrong on the outside. Will make jerky starts and then stops and then starts again. Same forward and backwards. Don't have mechanic nearby. Any suggestions on what is going on? Major? Barely made it to the barn. Suggestions?
mark
07-27-2002 19:12:47
 Re: Case 310 crawler won't crawl! in reply to dell, 07-23-2002 14:16:58
I have a 310 and I think is sold for parts ..If the guy doesn't pick up this week, it will be for sale again for parts..it has a good trans-axle..I will let you know ...mark_angela54@hotmail.com
david
09-08-2002 09:38:51
 Re: Re: Case 310 crawler won't crawl! in reply to mark, 07-27-2002 19:12:47
what the price and where are you located
Gary
07-27-2002 06:44:49
Sounds like ring & pinion gear trouble, you've probably lost a couple teeth on the pinion. I,m not that familiar with a 310G but it's a major job on most. See if there is an inspection cover that will allow you to see inside the bevel gear compartment; if not you can drain it & check for metal pieces. Hope this helps!
r_d97
07-24-2002 06:16:23
Check the driveshaft. Might have torn the splines out of one end or the other.
Edward
