Broken grease fitting
Polk Crawler
08-18-2002 21:04:49
grease fitting is broken off flush with hub on an idler; can another hole be drilled and tapped for a new fitting or must the old broken fitting be drilled out, threads cleaned to put a fitting in the original location? Have little confidence in drilling out the stub of the old fitting and saving threads. New hole tapped sounds easier???
Polk Crawler
george
08-18-2002 21:44:21
 Re: broken grease fitting in reply to Polk Crawler, 08-18-2002 21:04:49
grease fittings usually come out easy , use square
easy out ( not spiral as they expand the fitting
tighter in the threads ).
george
Bob /Ont.
08-19-2002 14:09:36
 Re: Re: broken grease fitting in reply to george, 08-18-2002 21:44:21
And if it doesn't move easy that way, heat it red hot, let it cool off, then it should nearly fall out.
Later Bob
Polk Crawler
08-19-2002 19:11:51
 Re: Re: Re: broken grease fitting in reply to Bob /Ont., 08-19-2002 14:09:36
Discoverd broken grease fitting is the least of my problems. Upon close exam on inside of idler hub , next to the shaft,found a large chunk of hub missing, broken and GONE. Any lube anywhere would have ended up to nourish thistle and morning glory at ground level.
What I really need, complete, is idler wheel with all the innards...bushings etc. Any help out there?.Zimmerman is a long way from Oregon...ought to be some parts source closer but maybe not. PC
