Cable blade stuck
Rich
08-27-2002 16:11:58
I can't get my blade to lower on my td-20 and don't have any info on the winch, any help would be greatly appreciated.
jim
08-28-2002 18:36:28
 Re: cable blade stuck in reply to Rich , 08-27-2002 16:11:58
Sounds like the brake is either stuck or adjusted too tight. It depends on which winch you have - most common one had the brake band that went around the drum - if machine has been sitting the lining could be rusted to the drum. On the winches the clutch engauged to raise the blade and the brake held it in place, when you lowered the blade the brake would loosen to allow the weight of the blade to turn the drum
