Waldon WD80 Dozer
Robert
10-08-2002 21:42:51
I am looking at purchasing a Waldon WD80 Dozer. Does any one have information on the reliablity of this Dozer?
It weights 11,000 lbs, would the machine have any problem leveling 10 yard loads of gravel?
What performance limits should I be aware of with a 11,000 lb dozer?
I understand Waldon has stopped manufacturing the WD80, how will this impact the market price for the WD80 Dozer on the used market?
eng42
09-21-2003 13:30:43
 Re: Waldon WD80 Dozer in reply to Robert, 10-08-2002 21:42:51
Reliability should be pretty good. I think they had some problems with the planetary gearboxes at about 500 hours, the track frame-to main frame bolt joint tended to loosen (later units were welded). They were good solid units other than that. You might turn the relief settings on the hydrostat pumps down a little to protect the gearboxes.
