Case 210B power steering pump
Whitney Cox
10-16-2002 17:59:10
Does anyone out there know where I can find a power steering pump for a 1959 Case 210B industrial? I would be happy to get it rebuilt if someone out there does this. Would this tractor possibly cross over with a standard farm tractor model?
t4mike
10-16-2002 20:54:36
 Re: Case 210B power steering pump in reply to Whitney Cox, 10-16-2002 17:59:10
Did you post this question on the Case board? You may get more and better info there. I've got a 210B too with factory loader. Do you have a back-hoe on yours? Knew they had em, but never saw one. I think they are to under-powered for commerical everyday use, but just fine on the 20 acres here messing around.
Whitney Cox
10-18-2002 14:43:13
 Re: Re: Case 210B power steering pump in reply to t4mike, 10-16-2002 20:54:36
No I did not try the Case board. I will post it there. The unit I have originally came with the hoe, but it was missing when I bought it. It still has the mounts for it, which I have welded to hold weight on the back. You are right about it being very small, but I use it to clean out chicken houses and need a low tractor.
