1010 diesal crawler burns rich
Roger
11-01-2002 09:10:59
Hi all,
I just recently overhauled a JD 1010 diesel crawler and it burns a bit rich. I tried adjusting the fuel pump per instructions, but doesn't seem to make much of a difference. Is this normal, or have I overlooked something?
Thanks,
Roger
AJ
11-01-2002 15:41:48
 Re: 1010 diesal crawler burns rich in reply to Roger, 11-01-2002 09:10:59
Do you mean you have black smoke,is the engine getting enough air,is the valves timed and set correctly,after a fuel injection pump is set up on a calibration machine there should be no need to make any adjustments to it after it is fitted and timed to the engine,you should work it for a bit and see if it clears up
AJ
