Boring wet sleeves
JerePa
11-26-2002 19:49:02
Has anyone had experience with boring wet sleeves. I want to bore my sleeves from 4 1/2" to 4 3/4". Any special tips you could provide will help. How to hold them in place also is another problem.
tim
11-28-2002 14:04:47
 Re: Boring wet sleeves in reply to JerePa, 11-26-2002 19:49:02
One way this could be done even if they are hard is to rough bore on a lathe. Then finsh on an ID grinder, You could use a mag chuck to avoid distortion. I can't believe this would be cheaper than buying new.
Bob /Ont.
11-27-2002 10:17:54
Jere, you aren't talking about Cat liners are you? They are hardned steel not castiron. They can be deglazed but I don't think you could bore them and make a good job of it.
Later Bob
george md
11-26-2002 21:28:53
Jere,
Depends on the wall thickness whether you can bore it , I bore wet sleeves quite often, but not for oversize. I bore sleeves to repair the surface, I bore and install a dry liner in the wet sleeve , works great for the ones that you can't buy parts for. Mostly do waukesha 190 DLC , the 190 DLB you can still buy parts for , also do the J series cont'l , JD 382 and JD 403 . george
clark
11-26-2002 20:13:57
you didnt specify what engine your wanting to bore. it is possible to get overbore sleves. i dont think you can bore a sleve, the walls would be too thin and burn up.
JerePa
11-27-2002 10:16:25
 Re: Re: Boring wet sleeves in reply to clark, 11-26-2002 20:13:57
My TD-35 has 4 1/2" bore sleeves. There is adequate material to bore to 4 3/4" as the block was designed for either sleeve. I am hoping that the boring cost is cheaper than buying new sleeves-that is, if I could even find new sleeves. TD-14 sleeves & pistons will interchange with my engine. Does anyone have a set of main bearings .030 undersize for a TD-14??? They are almost impossible to find. Thanks, Jere
kydavid
11-27-2002 17:17:31
 Re: Re: Re: Boring wet sleeves in reply to JerePa, 11-27-2002 10:16:25
A the risk of talking about a specific engine I haven't worked with, be sure about the sleeve wall thickness. While a block may be designed for either sleeve the sleeve may not be designed for boring. For example, the sleeve may only be hardened a few 1000ths. Working on a DT 466 now that has oversize sleeves available but they don't bore well. Guy that fixed it before tried to bore them and made a real mess of things, had a sleeve shatter under load, ripped a piston, and twisted the crank. He spent 3500 getting it done half way when 4500 would have done it right.
Suggest talking to a good machine shop and see if they can get you sleeves and bearings. There's a really good one I use, email me if you need the #.
clark
11-27-2002 14:16:49
Jere, try batescorp.com. they sell alot of IH parts. thats where i got my rod and mains for my TD-6. it wasnt cheap tho. cost me close to 800 bucks for them!
