1010c Bottom Rollers
Jerri Neese
03-13-2001 07:44:09
New to this crawler stuff and have just made an offer on a 1010c. The owner says the bottom roller need to be replaced. Can these be rebuilt, or is this a replacement item only? Any good sources for these parts? Last, a good source for a shop manual or repair manuals for these other than the dealer?
Thanks for any help,
Jerri
Lavoy
03-14-2001 21:46:26
 Re: 1010c Bottom Rollers in reply to Jerri Neese, 03-13-2001 07:44:09
Jerri,
Don't worry about rollers, I probably have 50 on hand at any given time. Let me know what you need.
As far as manuals, buy the Deere manuals, you'll regret it if you don't.
Lavoy
Jerri Neese
03-15-2001 04:24:44
 Re: Re: 1010c Bottom Rollers in reply to Lavoy, 03-14-2001 21:46:26
Lavoy,
Thanks for the help, will likely be giving you a shout.
Thanks,
Jerri
jerry gerthofer
03-13-2001 15:40:37
jerri i think machine shop should be able to rebuild that for you. fairly cheap.
Jerri Neese
03-13-2001 16:24:34
 Re: Re: 1010c Bottom Rollers in reply to jerry gerthofer, 03-13-2001 15:40:37
Thanks for the info. I will definitely look into that. At a $100.00 each, I can appreciate a lesser expensive alternative.
Thanks,
Jerri
Tom Rohrer
03-13-2001 08:46:24
Used rollers for a 1010 are as rare as hens teeth. There are new undercarriage components available that crossover from another model as I have just quoted complete undercarriage for a 1010. New single flange bottoms will run you about $170 CDN each FOB Delta BC.
