Case-Davis Scatback 430
JO
12-27-2002 13:09:17
Just purchased a 1976 Scatback 430 wheel loader. I heard these are pretty good machines. Does anyone know anything about these? This machine has one problem that is puzzleing me. The rool back bucket control lever works backwards. After investigation I found someone had switched the hose after a new hose was installed. At least that is what I thought. I switched the hoses and now the bucket will not hold any weight without rolling foward. It appers the Cylinder has been rebuilt. It works well if the hoses are hooked backwards. I am puzzeled.
Neil McAskill
08-09-2006 21:17:25
 Re: Case-Davis Scatback 430 in reply to JO, 12-27-2002 13:09:17
I have had a scatback 430 for about 15 years and love it. I don't know the nature of your problem sugget that somebody rebuilt the valve and did not reassemble the roll back portion correctly. I am looking for a new valve block as mine leaks badly.
TB
01-01-2003 16:27:18
I have one. The bucket has a self leveler built into it somehow let me look at my book.
GLENN FERRO
08-08-2003 18:45:02
 Re: Re: Case-Davis Scatback 430 in reply to TB, 01-01-2003 16:27:18
I have a 1974 model. I use it all the time and have rebuilt it from head to toe 3 times. I have a complete owners and parts manuals, also a factory HATZ diesel manual.I'm looking for a transfer case or the gears for one.If anybody has any problems they need help, with feel free to ask.
Andrew Mullins
12-04-2006 22:10:49
 Re: Re: Re: Case-Davis Scatback 430 in reply to GLENN FERRO, 08-08-2003 18:45:02
Hi just purchased a scatback loader it seems like a good little machine and was wondering what tyres you have on your machine?
glenn ferro
09-13-2006 18:10:08
To anyone having problems with a davis scatback 430 please call me at 352-465-4982. Maybe I can help you. I'm not good with computers but I am good with machinery.
Barb P
04-28-2006 19:53:58
I have a Scatback 430. Have you been able to find gears for yours? I am looking for gears as well.
Neil McAskill
08-11-2006 19:18:25
 Re: Re: Re: Case-Davis Scatback 430 in reply to Barb P, 04-28-2006 19:53:58
Have you tried companies that specialize in making gears. I would try that. Good Luck
Daniel Ficza
01-11-2006 12:32:12
I have a big problem with my Scatback 430.
I have been looking for the main gear sprocket(there are three, this is the biggest one, just off the hydrolic pump) for almost 2 months now. I even contacted the main office in Australia. It seems nobody is able to help me, because there is no serial number left onn the engine.
Would you happen to know where I could get one?
Any help is greatly appreciated.
Daniel, Prince Edward Island, Canada
Morley B
03-25-2007 16:37:10
 Re: Re: Re: Case-Davis Scatback 430 in reply to Daniel Ficza, 01-11-2006 12:32:12
This posting is over a year old, but did you ever find your gear?
Lee Coale
11-28-2005 20:13:55
I have scatback 430 I recently purchased. I am trying to find manuals for parts and service. Is there any way I could get manual numbers from you so I can order them? Case seems to have no idea where to find them. thanks Lee
Jim Worthington
03-13-2005 01:35:05
Hi
I have a 430 with the same problem. The curl and dump control seems to only work backwards. Do you know why?
Thanks
JW
Milesy
07-03-2004 04:20:11
I have just purchased a Case Davis Scatback 430 with a hatz diesel. I am looking for whatever books/manuals that may be available for it.
TB
01-01-2003 17:47:38
I have a break down of whare every thing hooks but the problem may be in the valve assembly. your email didn,t work
jo
01-05-2003 16:54:51
 Re: Re: Re: Case-Davis Scatback 430 in reply to TB, 01-01-2003 17:47:38
Thanks anyway. I finally got some books as well. Have you ever had any other problems or any tricks to prevent any problems?
MIKEL32
01-05-2006 10:45:12
 Re: Re: Re: Re: Case-Davis Scatback 430 in reply to jo, 01-05-2003 16:54:51
WERE DID YOU FIND THE BOOKS
TB
01-05-2003 17:31:26
We have had ours for over 25 years. So I have had some problems and learned a few things over the years as well. All we ever had was a parts break down book what other books did you find for it?
Toby Rhoads
04-09-2003 18:59:21
 Re: Re: Re: Re: Re: Case-Davis Scatback 430 in reply to TB, 01-05-2003 17:31:26
looking for a hydrolic cylinder head for 70s model Case 430 scatback loader - anybody know where I can find parts?
