Boom drop
john
01-12-2003 05:48:26
help backhoe owners how long should the boom stay up if extended out 12 ft or so and 2 ft off the ground and no lock vales
Greg D
01-12-2003 18:43:39
 Re: boom drop in reply to john, 01-12-2003 05:48:26
While you shouldn`t be able to see it fall right to the ground, the drift should be rather quick. Spools are a poor seal in the control valve and you say you have no holding valves in the system. All hydraulic machines will have an acceptable drift spec somewhere available. Good luck!!!!!
