Case 450 bareley will move
TY TRIBBLE
01-19-2003 06:56:23
I need help Ive got a 1976 case 450 dozer it was working fine then got back on the dozer motor running fine tracks barely will go. If you try to push something it just boggs down could this be a converter problem or charge pump. Any help would be appreciated.Thanks Ty T. Arkansas
Max
01-19-2003 09:01:16
 Re: Case 450 bareley will move in reply to TY TRIBBLE , 01-19-2003 06:56:23
This may sound stupid but are the tracks clean around the drive sprockets? Had a customer once that complained about no power on and 850, he ended up paying $150 to clean out the tracks and have the pressures checked. After cleaning, found out the parking brake wouldn't even hold the machine back during the tests in high range, high speed forward. Sometimes the most simplest items are overlooked.
