Case 509 model
Sawman
03-01-2003 01:19:24
where can i find out about this...would like to no what year it is and hp it is and where to find a starter for it ...it is being used as a power unit for a saw mill..any info would be appreciated...Sawman
Max
03-01-2003 09:04:36
 Re: Case 509 model in reply to Sawman, 03-01-2003 01:19:24
Its most likely a 504. these range in horsepower from 120 to 235, depending on the setup. The engine was available as Naturally aspariated, Turbo charged, Turbo Charged with intercooling. The reason I gave the hp rating of up to 235 is because I gave the flywheel hp and that was an estimate allowing for driveline loss for I ran a few of these on the dyno that pushed a strong 215 at the PTO. Also, these engines put out a lot of torque, not much torque rise because they started with a lot of torque. Top end was 2200 rpm and if you adjusted them up to 2500, their life span was shortened a lot.
